Wii Emulation Issues
Alright, so my end goal here is to get Dolphin/Wii emulation going on the PC.
Wii Motion Plus controller, check.
Wii USB sensor bar, check.
Bluetooth 4.0 USB adapter, check.
Granted, the Bluetooth adapter is Chinese. From the software, it looks to be a CSR8510 A10. I plug it in, install the included software/drivers and it's connected. I test it out using a bluetooth device, seems to be working okay. So I pull out the Wii controller. The model number is RVL-036. As far as I'm aware, this is a legitimate controller model, and all markings match the ones I've been able to find on a real controller. So I try to connect this to the PC. PC can't find it. Try it again, no luck. I did all the usual steps, like uninstall and reinstall everything, no luck. For notice, I tried to connect it using the red sync button on the back as well as the 1+2 button method.
Next, I read that Toshiba Bluetooth Stack might be a fix. So I uninstall the CSR Harmony software, and install the Toshiba Bluetooth. Still no response.
I can't think of anything else I can do to get this damn thing to work. Has anyone had any luck, and if so, could they name the bluetooth adapter/controller model/etc.
