WiFi: WPA Enterprise has stopped working
I usually use EAP-TLS to authenticate my WiFi but for some reason it has stopped working and I'm forced to use PSK instead. This is only happening on my laptop running manjaro, my phone still connects just fine. In the freeradius log I can see that the authentication is successful but on the laptop the connection always fails. Sometimes I get a popup asking for a wifi password but it doesn't work.
This is what I get when I run dmesg, I'm not sure which other logs to look at
[ 2542.137122] wlo1: authenticate with 24:a4:3c:c8:66:70
[ 2542.139332] wlo1: send auth to 24:a4:3c:c8:66:70 (try 1/3)
[ 2542.139949] wlo1: authenticated
[ 2542.146431] wlo1: associate with 24:a4:3c:c8:66:70 (try 1/3)
[ 2542.147415] wlo1: RX AssocResp from 24:a4:3c:c8:66:70 (capab=0x11 status=0 aid=2)
[ 2542.148374] wlo1: associated
[ 2542.187609] wlo1: deauthenticating from 24:a4:3c:c8:66:70 by local choice (Reason: 1=UNSPECIFIED)
[ 2542.201658] cfg80211: World regulatory domain updated:
[ 2542.201667] cfg80211: DFS Master region: unset
[ 2542.201670] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 2542.201677] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 2542.201681] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 2542.201685] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 2542.201690] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 2542.201695] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 2542.201699] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 2542.201703] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 2542.201706] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
Assuming you're using NetworkManager, have you tried using the cli instead of the gui? Might give more details about whats going on.
$ man nmcli
Is the dhcp daemon surely running on wlo1?
