WiFi PCIe adapter
Hello all,
I just built a PC and I need a new PCIe wifi adapter now to connect. I got a cheap one before and it wouldn't work properly, so I need one that has decently fast speeds for gaming and internet browsing and that can talk to the router (It's about 40 ft away through many walls on a different floor of my house, and there may be metal in my walls). My router is a netgear nighthawk ac1900 dual band and i have a i7 4700k with a asus z87-k mobo and samsung 840 pro ssd and 8 gigs of kingston ram (if this info is needed). Also, the card has to be below 20-30 dollars because I'm kinda out of money right now after building the pc. Thanks for all the help guys.
Cheers!
I use an Intel 7260 in both my computers they fairly cheap 40-50$ USD for dual band receivers and are really easy to get working.  The real question is what does your router broadcast 802.11a/b/g/n/ac? or 802.11a/b/g/n or what? You only need a card that has what your router supports anything extra and you are wasting money/future proofing. There is a Intel receiver in your price range +/- a few check out a Intel 62205(34$). If you want to spend a little less you get less range and less speed but if you stick to good brands like Asus and Intel you aren't likely to go wrong.
Why did you put this in inbox.exe?
