I was tinkering with old DS and PSPs and they rely on WEP or WPA (PSP can be weird as the wifi drivers are inside the games - Wipeout will force WEP for example).
I wanted to have a sort of PoE access point that I can plug in an boots up a compatible Wifi network. I can create an isolated network and all that, but I can’t find a device that I can just plug in.
I am getting close to converting a Raspberry Pi to do this, but short of spending that big dollar money (seriously 2026…) do you have any suggestions that I can use for this?
eBay or Mercari and old router supporting WEP that can be put into bridge mode (thus basically operating as an AP). Then set it up on the isolated network. If it doesn’t support bridge mode OOTB, you could also buy an ancient router supported by a WEP-era DD-WRT build, flash the latter onto it, and then continue with the rest of the process. You may be able to find an old enterprise AP that could work.
If WEP/WPA/WPA2 can be cracked and allow access to the network on the AP, an additional layer for defence might include allow-listing connections tied to the device’s MAC and block-listing all others so you drop unwanted connections. (Bonus points for taking a moment to think whether rate-limiting vs denial-of-service rejecting bad MAC’s is likely and worth the effort prevention.)
Yeah I know all that - this will go into a VLAN that will only have Internet access. In this day and age, WEP is really no security at all, the whole point is just to get it working while I want to tinker with a DS/PSP.
Get a cheap Alfa Wifi dongle and set it up as a AP and you can do internet sharing in windows.
Also, you havent lived until you played Wipeout on the 1st gen Vita (the OLED one)
Well the idea is to do nothing with the PCs, I don’t want to have a PC at the ready when I do this, sometimes you just want to sit on a couch and just have a gaming session without any hurdles to jump
