Wifi Adaptor for gaming purposes
I have a crappy D-Link DWA 110 wireless usb router running through  3-4 walls and getting full bars from my modem which is like 15 meters away. i have tested out the speeds on speedtest.net but unable to test the quality in pingtest.net
http://imgur.com/7sJzj2S
Your speeds are average for a lot of people. Unless you're supposed to be getting a lot higher download speeds, changing the usb wireless would be more or less a waste of $
yeah i forgot to add when in gaming like league of legends i get laggy gameplay during intense situations therfore making it not reliable. i need a good cheap-ish adaptor and my motherbord is a m5a99x exo r2.0
are you sure its the wireless causing the lag? what is your graphics card? in an intense gameplay on LoL it all comes down to your graphics not your network. my cousin was playing LoL on a wireless network only giving him 6mbps and he was able to play fine.
what ever you do do not buy realtek - spend a few more money units to get a proper card, not my words - words of Logan (in his inbox.exe vid.) I must support his opinion in general - it is better to pay a bit more and get decent equipment rather than go cheap and pay a lot more afterwards...
P.S. For better data transfer (after you upgrade to a PCi card) you can install stronger antennas (which have more dBi)
I just put in an Asus AC68 in my desktop, I would go that route for the AC compatibility since even the high end usb ones are like $50 might as well drop the $100 to get wireless AC and an amazing card.
i have a r9 270x amd fx6300
8gbs ram
i might get it but for 100 bucks maybe not too extreme for me
