Hi,
I seem to be having an ongoing problem - finding a decent way to connect my computer to my router.
When I built my computer (around 2-3 years ago) I dived straight in and bought an Edimax Pci card and I can honestly say it was the worst product I've ever bought. Never worked properly; my 3 year old laptop card had better performance.
Eventually it got so bad I decided to invest in a pair of power line adapters. They worked well for a few months until we had an extension on the house and now they only work intermittently at the best...
So a few weeks ago I splashed out and bought an Asus EA-N66 gigabit adapter which is slightly unorthodox from my experience but it worked. For a bit. My internet connection has started cutting out for 5-10 seconds every 10 mins or so. I have updated the adapters firmware and updated my onboard-nic's driver and the problem still remained. Its not the worst that could happen as when it works it delivers me with 60mbps. I am still investigating to check whether its the Asus adapter or my nic. Should it turn out to be the adapter I will return it and replace it.
MAIN QUESTION:
So where I'm going with this is what would people recommend to be a reliable medium range wireless adapter that could be considered 'gaming standard.' It's really boring me that nothing seems to work.
I recently considered that maybe my router is to fault? For any one from the UK its a virgin super hub. I don't think its to fault but I don't really know anything about routers etc.
Any help is really appreciated,
Andrew (Curymuncher)
LINKS
Asus adapter : http://www.amazon.co.uk/gp/product/B00864N9FK/ref=oh_details_o00_s00_i00?ie=UTF8&psc=1
Powerline : http://www.amazon.co.uk/gp/product/B0084Y9N3O/ref=oh_details_o05_s00_i00?ie=UTF8&psc=1
