I have an ASUS PCE-N10 Wireless Adapter (http://www.newegg.com/Product/Product.aspx?Item=N82E16833320071) and it sucks. I updated the drivers and it still sucks. I had to buy a USB Wifi adapter and it works way better than the Asus PCI Express. The Wifi adapter sucked on Windows 7 and it didn't change when I upgraded to Windows 8.
So could any of you suggest a Wifi adapter.
-Budget doesn't matter
-2.4GHz & 5GHz would be nice.
-Windows 8 compatiable
---The only thing that I want and has to have is great speeds that can go through bunch of walls without decreasing the speeds so much on it.
Thanks but what about anything thats PCI since USB can be slowwer sometimes. I was looking at this http://www.newegg.com/Product/Product.aspx?Item=N82E16833320136 but it's very very expensive compared to the other Wifi adapters. Are there some like this that is a little cheaper?
