Wifi access point over Ethernet cable
Hello all, to explain what am I trying to do
in my bedroom I have my WIFI enabled ROUTER. In living-room(which is approximately 50FT away from my bedroom) wifi signal is dropping that low that smartphones are unable to use.
I already have CAT 7 cable  running from my bedroom to living room
so I am interested if i buy another wifi router can I connect this  routers to each other with cat 7 cable and use 2nd one as access point(goal is to increase range)
my router is Netgear WNDR3400 with Firmware: DD-WRT v24-sp2 (03/25/13) mega
yes you just have two different access points
 I'd suggest running them on different channels
that is what am trying to avoid
I never have done multiple access points before and might be asking something that is impossible.
but what am trying to avoid is
If I have one access point named XXX and second one also XXX, if i am connected to 1st XXX and than  relocate closer to second XXX. i want second access point to take over the device so user did not had to disconnect from 1st access point and connect to much closer access point.
If you have the second router set up as an access point in DD-WRT, then you should just have to set the router up with the same network name and security settings as the first, but on a different channel. Devices will seamlessly transition to the strongest signal. I have the network in my home set up this way, with four routers and it works flawlessly.
Thank you i will do that
but where is the access point in dd-wrt? do you mean "Wireless"->"Basic settings"-> "Wireless Mode" "AP" ?
because right now I only have one router and it is set up as "AP"
and second question
does the cable between router one and router two needs to be crossover or not?
No no, that's you're Alfredo Pasta settings.
Good one
I almost went and looked for Alfredo Pasta in dd-wrt
I'm not very familiar with the ins and outs of DD-WRT, so I just set mine up the way I normally do with less capable firmwares. It works, but there may very well be a better or more direct way of doing the same thing. Here are the important bits of my config (I think anyway, maybe I'm missing something):
Setup:
Disable the WAN interface, manually configure the router IP for your network, assign WAN port to switch (hardware dependent, optional), disable DHCP server or set type to Forwarder,
Wireless:
Set Wireless mode to AP, set Network Configuration to Bridged.
You shouldn't need to use a crossover cable. The manual for your router only mentions that the WAN port supports both crossover and straight-through, but I'm willing to bet that all the ports are auto-MDIX.
