Why is my monitor stuttering?
I have an acer 23" 1080p monitor, th H236HLBID, its a beautiful monitor, thin bezel, cheap, ips, but it only worked for a few months. Now it has two horizontal lines running the whole width of the screen, about an inch from the top, and bottom, these lines stutter, never fully going out, not insanely noticeable on blacks, but its like a freaking rave on anything else, even greys. It worked fine until I plugged in an hdmi cable to hook it up to my cable box, when i switched back to the DVI input where my computer is plugged into, thats when it started having those stuttering lines. My question is, whats the issue, and is there a fix? I've got money for a new monitor, but I was kind of saving that for something else. Also, sorry if this is the wrong category, I couldn't find a specific category for monitors... not that I looked for a massively large period of time.
i have no idea what it is, but did you allready try a diffrent cable ?
i dont know if you have a spare monitor laying arround, of if you could connect your current monitor to a diffrent pc, just to determine if its a monitor problem of something else.
It may be worth blowing out the ports and cables, dust could be obstructing the signal
