Why is Graphics/Display so hard and is there a Distro that does it better than most?
(After writing this, this got longer and rant-yer than intended. I’m not trying to just come here and cry about how bad the world is. I’m genuinely interested in finding solutions, getting to now new Linux Distros that do things differently or get a hint in a direction to actually help fix this).
So it’s Monday. I’ve had a long weekend with a lot of playing with Linux. It’s what i like to do on Saturday evening. Sit besides my wife and look what All the distros are doing. And most of the time, distros fail on providing me a decent experience in graphics set up. I would really like to have something that works reliably. I don’t mind tinkering through a long setup. So what are my Problems?
Well first, i might not run the most Linux Friendly Setup to begin with. 1070 ti with 3 Screens attached. One 1440p 27" 144Hz, one 1440p 24" 60Hz and one 1080p 24" 60Hz. So mixed resolution, mixed DPI and Mixed Refresh rate. Adding to that, the 24" 1440p Monitor is turned 90 degrees. I see why this is not exactly “mainstream”, but I’m not interested in limiting my Hardware Setup for Linux. I have it like that for a reason. It’s what allows me to be the most Productive. Could i have gone AMD? Maybe, but back when i got my 1070ti, AMD Prices where outrageous. So it is what it is.
So with the setup i have established, here are some experiences I’ve had:
  • Fedora: Nvidia Drivers only work from Negativo. RPM Fusion Drivers don’t compile into the Kernel correctly for me and render the Install Graphics less. After Installation, The screens need to be set up in Settings. Then nvidia-xconfig, then nvidia-settings with root permissions. Set everything up and hope it survives a reboot. It does so in 70% of the cases.
    If the screen locks from time out, i loose the on End Monitor. No was to bring it back but to delete a Monitor.xml Only way i have found to mitigate that is disable switching off screens after a certain amount of time.
  • Ubuntu (and versions): See above minus the Repository thing. The included drivers are outdated, but since i don’t play overly intensive games, it doesn’t matter too much. I gave the latest Nvidia drivers a go, and it made no difference.
  • Elementary OS: tried that yesterday. That was fun, somewhat. I like their concept, but initial setup was bonkers. Before installing Nvidia drivers launching Epiphany would lock the screen. Upon re-login dock and bar would be missing. Same when changing anything monitors. Move them, turn them around in settings. Every change made the PC Lock. i was able to install Firefox, which worked, and install Nvidia drivers through ubuntu-driver autoinstall. After the System was updated and rebooted, It looked stable. further testing required.
  • Arch/Antergos: Depends on DE. Driver Installation is hassle free for someone who has some Linux experience. The stability and configurability highly depends on WM/DE. The best luck i’ve had was i3 or openbox with a logon Script that set my Monitors up through xrandr. Not exactly user-friendly, but at least stable. As soon as KDE or Gnome or any DE come into play, this wouldn’t work anymore.
  • Manjaro: Surprisingly good. Not great, but good. I used the Gnome edition. So the typical Gnome/Nvidia overriding each others settings stuff still applied. Other than that it was really good.
  • Solus: wasn’t even able to boot the system. Live worked (somewhat, with artifacts and such). Upon booting the installed OS, my screens woudl freak out, render weird triangles and distorted pictures and such. No way of fixing it in that state.
I’ve tried most other common Distros, from CentOS, over Debian to trying a Gentoo install (got it booting… without USB duh!). It just seems that getting any setup other than Intel/AMD with a single screen to work is rage inducing. I don’t expect Windows level performance out of my GPU. All i’d want is my preferred settings to apply and stick over reboots, sleeps and updates. And this isn’t even talking about no DE getting a smooth 144 FPS with VSync. They all Tear, lock to 60Hz or lag (compton).
I know that my Mixed Refresh Rate setup is not addressable in X. And i also know that Nvidia + Wayland isn’t a thing yet. But why can’t any Distro i tried get a reasonably complex Monitor Setup configured and saved correctly?
I’ve got a 1070 ti with 2 screens (60hz)
I’ve experienced none of this trouble, except the RPMFusion repo being ahem a fucking broken piece of shit.
Did you try this through Gnome? I had never had a problem with it setting up properly. In fact, I never even touched nvidia-xconfig or nvidia-settings. It just worked.
Of course, I’m on KDE, so YMMV, but it might be worth trying without touching nvidia config tools.
nomodeset is your friend. Fix this, then go in, install the drivers and see what the results may be.
Yeah it seems most of my Problems revolve around the 90 degree turned Monitor. Once set up in Gnome Settings and Nvidia settings it seems okish. Monitor Sleep still breaks it on any gnome desktop i tried other than Manjaro so far.
Oh yeah. Haven’t used that in a while. Maybe i’ll give it a go tonight. Great idea. Thanks!
I just hate xrandr… I wish it would work right with custom resoultions and spacing anyone who can build a better “screen manager” for desktop environments would be getting donations from me…
Untill then finding the best one is subjective personally I love deepin Linux… But has the same issues as Ubuntu for multi screen that you are describing.
Personally deepin seems to be cleaner then Ubuntu and debian… Like crisper images on deepin vs Ubuntu/debian only issue is using neck beard council debian approved GPU drivers so not too new but useable from the GPU driver ulti very gui centered settings.
Might be worth a shot but I have my doubts
I feel like a lot of the Problems i personally face would be solved by wayland mid-term. To bad Nvidia doesn’t play nice with Wayland. Any my integrated graphics doesn’t have enough display outputs to test this hypothesis. My work notebook with intel Graphics and three screens doesn’t face as many issues. But the setup is “easier” as they are all 1080p, 24" and in “normal” orientation. So who knows.
I really hope that, maybe with RTX out, Nvidia is willing to start to work with Open Source. I feel that RTX is their new thing. So maybe they are now willing to work with the Community to get their “old stuff” working properly. One can dream…
Honestly getting odd resolutions and orientation work is fun
would recommend looking into setting xrandr settings and such
Nvidia breaks on reboot and xrandr breaks Nvidia no fix
I’ve honestly debated staying with nouveau drivers for once. They worked really smoothly in Elementary (well apart from the, do anything and get locked out thingy).
I always felt the nouveau drivers produced better results in terms of Desktop use. They tend to run smoother for me. Since i don’t do any high-end Gaming atm (or dual boot windows for that), they might actually suffice. I haven’t done extensive testing with those in years.
Last experience I had with nvidia was a single monitor. I had the issue with my settings not being persistent after reboot on Ubuntu Gnome using nvidia drivers. Had to manually edit the xorg.conf. And on initial system installation nomodeset was necessary in grub to get my desktop to show up.
Its silly I know. To build a desktop environment it seems like video would be the top priority, but then again I’m not a Linux developer.
being a developer when building a distro you chose the drivers that work for your hardware during development. but not all users have the same hardware.
usually you are checking a hal for the best drivers you can use. but sadly it may not cover all hardware. this is also true for wireless, printers, etc.
there are work arounds you can use but its best to visit the distro’s user forums first!
most often you will find the answer there or someone will find it for you.
So while my setup isn’t quite as unique as yours, I still have a 1440p 144hz monitor and a second 1080p 60 hz monitor.
The first issue on ANY os is the refresh rate. I’m not an expert at this, but the difference in refresh rates cause the GPU to boost up to a high clock, making the temps a little higher then they should even when usage is slow. What I’ve been doing is knocking the refresh rate of the 144hz monitor to 120 hz. There’s something about the 120 hz being 60 * 2 that makes the driver not boost the clock, I believe it’s a memory buffer issue. This isn’t a Linux issue, I have to do this on my Windows partition as well.
The setup that works best for me is KDE. In the compositor settings, I turn off any vsync that kwin likes to do. On my 1080p monitor, in nvidia-settings, I force the composition pipeline because the tearing is very noticeable on that.
And after that, my setup works fine. The window dragging on the 144hz monitor is probably still at 60 hz, but it doesn’t bother me. On top of that, when you launch a game, Kwin will shut itself off until the game closes. This means you’re getting the silky smooth FPS you’d expect.
This is all on the Manjaro KDE edition. I haven’t had the issues you’ve listed on GNOME either, the only issue is GNOME’s tendency to force the GPU to run at max clock speeds, but that’s a GNOME problem no matter your setup.
If you use nouveau, you are seriously crippling the performance of your 1070 ti. Most games will not run properly. It may works if all you do is standard desktop stuff, but why have a 1070 ti then? Just my two cents.
i agree
one of the reasons i posted being careful with overclocking and pushing the envelope of performance is that it can cause damage to components if you go too far.
but its also a good way to expose a weakness
I am not a heavy gamer so i dont need the mach 1 performance! but i do need dependable hardware as my equipment runs 24/7/365 (with exception of maint. shutdowns.
you will find bugs in any software whether is linux, win, or mac, no one can write perfect code all the time.
but what sets us apart from the masses is we know what to look for and how to work around the pot holes before us.
So i just gave the latest Solus build another go. They seem to have done quite some work since i last checked it out 3 or 4 months ago. This Installation went insanely smooth. Thanks for making me try it again. And nomodeset wasn’t even neeeded.
After initial login, i had the same Problem i had with elementary, that changing screen orientation on nouveau drivers would log me out instantly and not keep the settings. After Installation of NVidia Drivers that worked though. Plus they currently ship 410.78, which is as new as i’d ever need.
The typical “set the layout in gnome settings, and in Nvidia-settings after that” with for composite pipeline was needed. I’ve not rebooted yet or let it sleep. So we’ll see. But currently, Budgie is running really, really smooth. I have not had a single hiccup so far. The Store has most things i need, but discoverability is a little sub par. No screenshots and no “sort by” thing or such. But i have not had to use the commandline to install anything yet, which is what i’d typically do on any other distro.
Also, this is the first time i have installed discord on Linux and it’s actually running smooth. Normally i’d would introduce noticable stutter or lag to other windows. Not so far.
Thanks for the tip. I’m trying that now. Although Budgie was noticably smoother than Gnome beforehand, it seems to have made dragging windows a little more responsive. I’ll be keeping an eye out for that. Also, no tearing in the Browser when Scrolling so far. That was an issue too. I’ll see how this holds up over reboots and sleep and such.
I should have clarified that the latest ISO (which was released a couple weeks ago) is working wonderfully. I didn’t know when you’d tried each distro.
Yep, up to date-ish drivers usually solve the problem if the distro is configured properly. Sorry to hear Fedora didn’t do it for ya though (#fanboy). At least Solus worked.
Glad to hear it! I hear screenshots are planned, but not a priority. Also, if you come across a missing package, they are leaning heavily on flatpak/appimage to fill out the rest of the software availability.
Oh i’ll take a solid Install mechnism over screenshots any day (cough.. Discover…) I was able to find everything i needed so far (including steam, wine, winetricks etc) and it installed it as expected.
Also great to hear they are leaning towards flatpak. My experience with that has been much better than snap. Snap packages have been overly slow for me.
Yeah, snap is alright, but it feels waaay overengineered and that makes it feel clunky and slow.
Ok, first reboot and we’re somewhat back to square one. It kept my Display configuration, which is great. The 90 degree monitor is now unusably slow. like, 15 seconds to maximize firefox. Scrolling goes a bit every second or two. Also, Discord is back to lagging the system out. And now the left 1080p Monitor has gotten some tearing going.
No clue why. I installed what i mentioned (steam, wine, discord, no configurations done yet). Overall the whole system now feels unresponsive. I’ve put the turned monitor back to “normal” orientation. That makes it better. Still, scrolling in firefox feels incredibly laggy.
Also tried setting my 144Hz monitor to 60Hz, which didn’t change anything sadly.
Edit: it’s really weird. I tried some more. So, after a clean restart, just a Explorer instance open everything is smooth. Open Firefox, lag comes back. Open Systemmonitor -> Lag. Close any of those -> smooth. Widescreen 1440p -> No Problem (responsiveness feels low), 90 Degree turned, windows are fine, fullscreen lags the hell out.
I’m now going to try the 415 drivers. Someone in the Solus Forum said the 410 Driver had a problem with x loading before the driver or such…
Another satisfied Solus user.
We should start a cult. With pitchforks.
Too bad Arch currently fills that Void :smile:
It’s G-Sync. Make sure that’s disabled in nvidia-settings
Happens to me on Solus as well. Once G-Sync is disabled (even with 144hz) it works smoothly.
Yeah, now i’m not even able to get any Nvidia drivers to work. I tried installing nvidia-beta. Those didn’t boot to graphics.
After removing any nvidia package i’m back to graphical boot with nouveau. Reinstallation of the default 410 driver that worked before doesn’t now. I can only boot to TTY.
I might start fresh tomorrow as i might have screwed something up with trying to install beta drivers. Who knows.
I’ve not had success with these on any Linux operating system.
I would try one more time, if you’re up to it. Disable G-Sync and then play with your monitor settings. It may help a lot (it did for me). I had a very similar issue. Mouse lag by several seconds, really, really bad desktop performance. Once I disabled G-Sync it worked as it was supposed to.
