hi all
for long time now one of my first goto items when doing a new win10 install was to uninstall
edge, and then remove internet explorer.
basically as administrator, you go to the folder that has the setup.exe
and its like setup --uninstall --force-uninstall --system level
however sometime in the last few weeks it has stopped working, have microsoft snuck in an update
to block this ?
anyone have a work around ?
I used this guide to remove windows store before
If you have no use for Modern (Universal) apps, here is how to remove all bundled apps in Windows 10.
Est. reading time: 3 minutes
this guide tells you how to use get-appxpackage
to find edge’s package name
get-appxpackage *edge*
then you run
Remove-AppxPackage {output from get-appxpackage *edge*}
Silly me never even thought of force removing thru PowerShell . For long you could remove it with the installer though by passing those switches on the command line .
Fyi this doesn’t work/work anymore
