It is crazy to me how little improvement there is between phone generations these days.
I just did a feature comparison between my previous Pixel 5a and my current Pixel 7 Pro, and then I threw in a Pixel 10 Pro for good measure to see what I am missing out on, and for anything that matters it is absolutely nothing.
I don’t care about or want any AI / assistant (on or off device) or cloud features.
My phone is essentially an email/web/and 2D utility device.
The CPU of even my old Pixel 3 and maybe even older devices would probably still be fine for what I do, if it were still supported. I didn’t really even need 5G. I mean, 5G was a wimpy upgrade over LTE anyway, making little to no difference. And LTE was more than sufficient being able to mimin low level home broadband speeds in many cases (though now that they have been dismantling LTE service and replacing it with more 5G service, that has come in handy)
The GPU performance is almost completely pointless to me. I have never had a game installed on any phone of mine, and never will. Not even a basic 2D puzzle game.
Higher resolution Cameras? Who who cares. the megapixel numbers are just marketing bullshit anyway. The shitty little lenses and tiny little sensors that fit in a camera are the bottleneck here anyway. You could give them a gigapixel sensor and it wouldn’t make a difference. Nothing over 8-10 MP makes a difference anyway. My 16 year old 12MP Nikon D90 dSLR still takes better pictures than any phone on the planet.
In comparing my Pixel 7 Pro to the latest Pixel 10 Pro XL, there are only two things I can see that may have improved.
1.) The screen gets much brighter (1500 nits peak vs 3200 nits peak). I imagine this would be useful in bright direct sunlight.
2.) Battery capacity. There has been a ~4% battery capacity upgrade in going from my Pixel 7 Pro to the 10 Pro XL. (5,000mAh vs 5,200 mAh) More is better I guess, but this is marginal at best.
Heck, even if I go all the way back to my old 5a, there is barely anything worth upgrading for. I wind up coming back to the same two things. The brightness was much worse on the 5a, and the battery capacity was a bit lower at 4,750mAh, but the truth is that the old Snapdragon chip in the 5a was much more efficient, so in real world use I got MUCH Better battery life with the 5a than with any newer Google Tensor based model.
I guess there is absolutely no reason to get any newer phone. It’s completely pointless.
