Why does my HDD show up like a USB device?
Here is a screen showing my HDD showing up like a USB device or at least thats how I would describe it. Look in the bottom right corner of the screen.
http://img339.imageshack.us/img339/3024/30377427.png
nice background, it shouldnt show up like that if you are using an internal sata connection, but if you are using usb or external eSATA then that is normal. Its not really an issue anyways.
I'm using one of the sata cables that came with my motherboard. Asus Sabertooth 990FX R2.0
Any other ideas?
Ok I figured it out. It was a simple user error :/ There are 6 AMD Serial ATA 6.0 Gb/s connectors (7-pin SATA6G_1-6 [brown]) and there are 2 ASmedia Serial ATA 6.0 Gb/s connectors (7-pin SATA6G_E12) and they are white. I had my HDD in SATA6G_E12 port 1 because I thought the white colored ports were ports 1 and 2. Turns out I was wrong.
