So i’ve got tons of HDD’s laying around my house which I often move between computers, and for whatever reason, two “new” computers that I got recently don’t seem to want to ever hot-swap HDD’s, and it’s super annoying. They are my HP Z420 (with two different SAS controllers, more on that later), and Lenovo M93P.
For my HP Z420, I’ve tried two different PCIe based SAS raid controllers, both set to JBOD, and neither allow for hot swapping HDD’s. Whenever I try to hot swap the drives, disk management continues to show the drive which was removed still “available” to the system, or when I install a new drive, disk management doesn’t acknowledge a new drive has been installed. The controllers I’m using are the HP P212, and an AMCC 9650SE (8 port). I haven’t tried the onboard sas controller yet, because I have no plans to use it (not enough sata ports for me). This is running Win 10 Enterprise LTSB.
For my M93P, same thing happens; disk management continues to show the drive which was removed still “available” to the system, or when I install a new drive, disk management doesn’t acknowledge a new drive has been installed. However, in this case, the drive is connected via sata to the onboard controller. This is running Win 8.1 pro.
In both systems, the HDD spins up, and upon restarting the computer, the drive is then recognized by the system, however, once I disconnect the drive from the system, once again, the system doesn’t acknowledge that it has disappeared. Also, in both systems bios/UEFI, neither have an option to enable or disable hot-swap (my old Gigabyte GA-Z170X-Gaming 3 had that the option).
Honestly, I’m stuck. I really need hot swap to work, and it doesn’t seem to want to, and it’s annoying. Any help/suggestions is greatly welcomed!
