Why differnt temp readings?
What's the Difference between the
ASSUSTeK COMPUTER INC,>Temperatures>CPU
and
AMD FX-4100>Temperatures>Package
The Program Core Temp is displaying the 2nd one but the Asus Sensor Recorder uses the First number
 [IMG]http://i617.photobucket.com/albums/tt252/animepunkw/hwm_zps0dc22993.png[/IMG]
 [IMG]http://i617.photobucket.com/albums/tt252/animepunkw/coretemp_zps1b598301.png[/IMG]
Ummm im pretty sure the first is your mobo and the second is your CPU, slap me with a pickle if im wrong.
Unless you room is at -5c id say that the only real reading is the Mobo>Temp>CPU, something obviously up with the software.
perhaps his computer is in the freezer.
I'm in Canada it is just colder here..
