Hi guys,
when I try to post something like a pathname or a shell command, I get "Error 403 Forbidden".
File examples:
/etc/ shadow
sudo cat /etc/ shadow | grep root
If I remove the space between "/etc/" and "shadow", I get the error and cannot publish my text.
Command example:
ps au
works. Trying to use "ps au" with "x" doesn't.
It doesn't matter if I use preformatted text, code or whatever.
@moderators is that a known issue? Is there a way around it?
sudo cat /etc
/shadow | grep root
edit: here's an ugly work around. Copy and paste works correctly.
403 errors on certain content within attempted posts are also discussed here
Also, the @moderators tag does not work. I think it requires fixing.
Going to close this thread, so please read through the linked threads above and use those to continue the conversation if needed.
