Why am I bottlenecked, and what by?
Hey guys.
First of all, forgive me if this is in the wrong category. There wasn't one that was general hardware discussion, so I opted for the most relevant type of hardware.
I just bought a 7970 in preparation for BF4, and was having some real framerate issues with the beta. I discovered I was among many with similar symptoms.
It wasn't until I went to play BF3 that I noticed something was off. On my previously selected settings (for my 550ti), which had everything on low except medium levels of antialiasing and high effects, I was getting the same frames as with my 550ti. But, when I turned up the settings, the framerates didn't diminish as I might have expected if there was something wrong with the GPU.
I have determined I am bottlenecked, but I don't know by what. My guess is the system ram, but you guys let me know.
Core 2 Quad @2.33 GHz
8 GB 533 MHz DDR2 RAM
Stock HP motherboard with one PCI-E x16 (first gen).
Asus AMD 7970 Direct CU II OC'd to 1050 on core and 6000 on memory.
I was told in a previous post I made that my system should be fine, and this card wouldn't be bottlenecked.
I've done a clean install of the drivers (first with 13.9, then with the beta drivers 13.10b), ran the GPU through multiple benchmarks (in which it passes with flying colors, as all 7970s do, so I know it's not a faulty GPU), and checked for windows updates multiple times (it comes up with nothing).
Am I bottlenecked by hardware? If so, what is an inexpensive temporary solution that can hold me off until I can afford higher grade components, but won't bottleneck my GPU by much (preferably none at all)?
Thanks for your help, guys. Have a great day!
- Alpha Spartan A
Your platform, motherboard/cpu/ram, is bottlenecking your GPU.
