So I never owned a mechanical keyboard. And I know what kind of switches there are, but what will the benefit be just using mechanical switches?
So right now I am using a free keyboard that came with an earlier prebuilt pc that I bought earlier. Now the pc is absolute crap, but this keyboard rocks. It is a nice membrane keyboard and I do not feel it needs much pressure to hit keys. It typs great, and connects with ps/2 nativaly. I can get good accuracy in games, so why are there keyboards that cost so much more?
So if I was to buy mechanical switches I would buy red switches just because they are quiet and do not need alot force to push, also the actuation point is 2mm, and are mushy as membrane keyboard. But what is the benefit?
One complaint about this keyboard would be maybe N-key rollover support, or it could be some games not supporting it correctly.
Is there a way to test N-key rollover: http://www.gigahype.com/nkey-rollover-test-page/
I can sometimes press 2 keys and sometimes up to 7, not great I suppose, and when I reach a limit it beeps which is very annoying >.< are there some hacks for nkey rollover, I guess not?
So might this be an option: http://www.amazon.com/Sharkoon-Skiller-Gaming-Keyboard-000SKSK/dp/B009K7QB8O/ref=sr_1_25?s=videogames ? But also they say it is loud, and it does not specify the typ keys.
Or I might buy a Quickfire Rapid which seems to be a very nice and simple keyboard. I like that it is a bit more customizable and stylish.
Just wondering
