Who needs a 670
Hey all!
Basically, I need to figure out what a 670 is capable of and who requires this power for their build(e.g. gamer, renderer, programmer, etc)
I'm looking to build a new PC and this is about what I was going for:
http://pcpartpicker.com/p/M4xe
Now the CPU fan and the PSU are different because part picker didnt offer the ones i chose(im in Germany).
The ~1000 Euro price tag has put me off a little.. I want a gaming PC that will be able to handle games like Battlefield 3, Crysis 3 and similar games on the maximum or almost maxed out settings. My question is do I need a 670 for this or will a 660 or another cheaper card(AMD also) work just fine? Also, if I want to screen record and maybe render some things will this be an argument for staying at the 670 level or is it more or less irrelevant? Lastly, if you make a suggestion I would appreciate it if you suggested a card in full context mith manufacturer and exact version..
Any questions feel free to ask!
Thanks!
try this http://de.pcpartpicker.com/p/M4xe
I'd recommend probably a 7870 XT as it is only beaten by the 670 in 3 fps but is a lot cheaper http://www.techradar.com/reviews/pc-mac/pc-components/graphics-cards/sapphire-radeon-hd-7870-xt-1130535/review
