Otaku
21
get the best one you can buy right now and then upgrade your other shit
its pointless buying a shitty card because your other components are shitty
yes it will bottleneck
but who gives a fuck because when you upgrade your other parts it wont
if you have a 9600gso and you upgrade your cpu
you will be sad you didnt buy a 9800gtx :P
Ok, I've narrowed it down to these three:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4209965&CatId=3585
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4116773&CatId=3670
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130397
So what do you guys think?
ummm there all the same card except for the second one is overcooked
i would go with the evga one its dual slot and you can over clock it yourself
choose newegg one if u have room for 2 slot cards
Ok, that's what I thought. Thanks for the help guys and merry christmas.
