Personally id say the x58 platform as you can always upgrade the ram to 6gb or 12 as your doing rendering it will help to have future expandability, also 1336 will support the new 6 core and 8 core cpu's when they are fully developed meaning that one mobo as long as the bios will support it will last you for years just like 775 did when core 2 came out.
That was ridiculous, AMD will of course eventually beat the i7. You also dodged the complete other half of the statement, what are CPU's good for these days? I don't find much use for mine other than Blender 3D.
wait for the i7 930. not big a difference, but a 200 mhz higher clock speed. it should be out this month. god damned, i want to go ahead with my second pc, which would be my main one, an x58 system, but my god damned friends keep pushing me to get a 360. im not going to sell my current pc which would allow me to get a ps3 and a 360. only reason i would bother with a 360 is to see whats going on in live. get the gigabyte board which is sub 200 and has usb 3.0 and sata 6gb/s even though its blue.
Yeah thanks bro, didn't know that Atom's didn't turn on computers. Why bother spending hundreds on a CPU when the GPU does the mans job? Your sarcasm is garbage, keep it outta here.
What do you mean by render? That's a pretty arbitrary word don't you think? If by render, you mean decode, then my GPU does that too. If you mean edit, and then render the project, then the CPU does do that, for now. I'm sure CUDA could do it a lot faster.
