Which Power Supply for This Build
I'm looking for a 80+ Bronze Power Supply, Preferable Semi_Modular for thisbuild: http://pcpartpicker.com/user/OceanMonkeys/saved/3bbM
I'm looking at these power supplies: (Is 500W enough (including overclocking). If it is I'll probably go with the cx500m)
http://pcpartpicker.com/part/evga-power-supply-100b10500kr
http://pcpartpicker.com/part/raidmax-power-supply-rx535ap
http://pcpartpicker.com/part/coolmax-power-supply-zu500b
http://pcpartpicker.com/part/corsair-power-supply-cx500m
http://pcpartpicker.com/part/ocz-power-supply-ocz550fty
http://pcpartpicker.com/part/raidmax-power-supply-rx530ss
Thanks!
You could capably run that on an XFX 450, which is both cheap and high quality. However, it isn't modular.
When I tried to find out the power use of the 7870 I had to look at reviews, and I recall they reported 120 Watts sustained.  For your CPU I'll guess 100 Watts TDP but it would be good to find out.  That's 220 Watts total.
To estimate PSU needs, I look at the PSU's specifications for the 12 Volt rail, which for the cx500 is somewhere around 35 Amps.  35 x 12 Volts is 420 Watts.
If the requirement for sustained actual power use (220 Watts) is 50-75% of the capacity (which is 420 Watts) then that is OK.  PSU's are supposed to be most efficient at that load point.
For over clocking you have to estimate your power requirements.  Another consideration is heat.  If you want to allow for your case to get warm inside, then a better PSU than CX is desirable, because the CX is rated at a relatively low temperature.  If the PSU is at the bottom of the case and draws fresh air from below this is less of a concern.
If you bump up to a commercial grade PSU such as AX then you won't have to think about heat so much.
Corsair has a nice chart showing all the relevant information on all their PSU's.
XFX550W pro is a nice unit indeed its not modular. Also the corsair CX500M is not a bad choice, never read bad reviews about it. its not the best build quality, but still its nicely single railed.
