I have built two $600 gaming pc's on pcpartpicker and can't tell which one is better for gaming. Before you say the one with the better gpu is better, a game i'm interested in playing is Minecraft which I heard is pretty CPU Dependant. But I also wanna play other steam games. So please Tell me which one is better.
BUILD 1:http://pcpartpicker.com/user/swag_69/saved/3vVQ
BUILD 2: http://pcpartpicker.com/user/swag_69/saved/3uO7
The 2nd one is like $40 bucks more expensive but that's not a big issue. Thanks! This is my first post!
Your parts listing are private :<
The first would be better. However, I highly recommend you get a newer and better motherboard, such as the Asus M5A97 (NON-LE) R2.0, or the Asus M5A99FX Pro R2.0 if you can afford it. The latter one is much better, and is worth the extra price.
Also, Coolmax PSUs are complete crap. A Corsair CX500 would be a much better option.
For gaming, largely due to the GPU, the AMD build will be better, but you will have significantly less CPU performance than the core i5 build.
for gaming, definitely #1
Revised AMD Build.
http://pcpartpicker.com/p/2FX37
Revised to add in a Hyper 212 Evo for cooling. Brings the price to $621. Save $30 by not buying the cooler, not recommended however.
I built nearly this exact same build except with a different GPU (Back when the Radeon HD 7870 Ghz Edition with a nice cooler was only ~$150) for my brother. Works fabulously.
add in a Cooler Master Hyper 212 EVO and you've got a winner here... proper mobo for an AMD FX CPU and decent PSU being the big upgrades...
AMD's CPU coolers are coasters... but yes, get this with a decent CPU cooler... might splurge on the Corsair 500m depending on the case's cable management...
I added the Evo. Love that cooler.
I stuck with the non-modular PSU. Saves a bit and cable management in that case isn't too bad.
That is indeed a pretty good build. The Hyper 212 is well worth the thirty bucks.
