Which parts need power?
Is it everything not plugged into the motherboard? (and in some cases the video card?)
This is my first time and im missing proper cables and such, ugh
I've got plenty of power cables though
??? going to need more info than that
Parts that need power:
HDD
Optical Drive
Mobo (both 4/8pin and 24 pin)
Graphics Card (if needed)
If you don't have all the connections you need, you can buy adapters that can be used for your setup. It would help if you had more specifics by a long shot.
Well my motherboard isnt on pcpartspicker nor did i use it for more than to find one price, and the last time I posted all of the links I got told to use pcpartspicker as an answer
Its a very generalized question, I'm not asking which of my parts need power. I'm just asking out of the main parts to make up a computer which ones need power?
Motherboard (yes)
CPU (no)
Ram (no)
HDD/SSD (yes)
Optical Dive (yes)
Fans (from motherboard)
Video Card (high end=yes)
