heres the link that_kid - Saved Builds - PCPartPicker
Any feedback is appreciated
The "Saved Build: Better amd with 7850 gpu"
and which mobo
this one :http://pcpartpicker.com/part/asrock-motherboard-fm2a75mdgs
or
This one:http://pcpartpicker.com/part/asus-motherboard-m5a78lmlxplus
"Better amd with 7850 gpu" is the best of them all. The ASRock FM2A75M-DGS will not work with the FX-6300, keep the motherboard currently in the saved build.
To be clear: http://pcpartpicker.com/p/pf5x
oh ok thanks for the advice
