I'm currently looking at two noctua coolers, the nh-u12s and the nh-u14s, which one would be better for my system, I would like at least 4.5ghz from the cpu, my gpu is in the first pci-e 2.0 slot, i figure a nice overclock to about that will satisfy for the time being but which one is better? which one would be a better size for my system? also I will be getting another fractal fan for the front of my case
Fitting a d14 will depend on whether you have tall memory or not. (unless you swap the front fan to the rear or remove entirely and just use the middle fan)
If you can fit the d14 and afford the extra $$$ sure go for it, otherwise the u14s is my recommendation as it is such a well designed cooler with great fans.
thank you, you've been a great help, I donT have tall memory and looking at the compatibility list it should be fine, it only costs another £5 so if I can get a slightly higher overclock then i shall be going with that one
Honestly, the NH-D14 takes up too much space and it's really difficult to work inside your case. I would suggest the NH-U14S since it's much quieter and takes up less space. You can see that the NH-U14S falls behind the NH-D14 by only 2C in this review.
