I want to create this simple network in my home, I do have more than basic knowledge of networking, but I do not know much about NW equipment, so, please help me buy the right ones
I’m ok for any design modification.
2 4 port eth nics and 1 2port nic in server will allow server to do jobs of ddwrt and switch,see netsh ras for setting windows ip4rtrtype/ip6rtrtype
Run windows as vmachine under server even if server is windows for extra security(yet extra setup time)
I lean toward using a pc as router/switch as 32mbyte router mem to 2gbyte of ddr3 is no contest and added horsepower of a cpu is just cherry on extra ram iceing on the pagefile hdd cake
I have hear good thing about Ubiquiti products. I am more for getting away from IoT devices however. If Ubiquiti is lazy patching or just EOL a product. Your buying gear again or are unpatched on the internet. A router / modem can last a decade easy.
A PC-router is what your DD-WRT router is. Linux based alternative OpenSource firmware suitable for a great variety of WLAN routers and embedded systems.
PFsense is one of the popular open source PC-router software. Maintained and patched.
PC-router as in it just any pc with a network card’s
This is the setup I run, Pfsense on a VM. I gave ubiquity as a more drop in and forget solution and very easy to setup. Don’t think most users are into the setup and control of Pfsense but if OP feels up to the task I would definitely say do it!
From what I’ve observed they seem ok (way better than typical Asus/Netgear/TP-Link)
If you’re going with 2APs+switch+router and paying ubiquiti, you might consider getting unifi variants instead of edgemax variants of products just so you could manage them all together from the same ui.
This home server you’re mentioning on vlan10 could be useful for running the unifi controller, otherwise throw a raspberry pi b+ and an SD card in your shopping basket
Another vendor you may want to consider is Mikrotik. Get a hAP ac2 and a pair of cap ac, and you’re done)
They’re in a similar class as ubiquiti (ie. long term upgrades), their UI is not as friendly and their wifi is typically lower spec; but they are cheaper.
Windows netsh
And microsoft tech documents sites(load balancing with netsh)
But as stated theirs setup time involved
And things are totally not under menus you would expect them to be
Netsh ras set (type, user, wanports) are few things needing setup
Need to link interfaces used to “router” being built
Netsh interface --have many things to set here as well as netsh netio and netsh rpc for remote admins and routers use firewalls so netsh advfirewall need router have a profile and rules setup
If wireless radios then neth wlan interfaces need setups(or mbn if mobile)
Need netsh dhcpserver(non server os doest not have by default)
Need to goto windows add programs and then add features/components and install internet tools and such for services needed(smb direct/multichan, ftp, etc)
Setup sucks as takes time(alot can be done with import tool of netsh)
Note netsh add helper
Fun tool
