after looking at different configs foe a pc i have decided on fm2 the a10 5800k and i want to do a small formfactor build so there are two m-itx fm2 bourds on newegg this one http://www.newegg.com/Product/Product.aspx?Item=N82E16813157340 and this onehttp://www.newegg.com/Product/Product.aspx?Item=N82E16813130664 and the sarock can support up to 2600 memory but the a10 only supports 2400 then the msi only supports 2133 so i was wondering is there going to be that big of a difference for the integrated vid card on the a10 or does it not matter that much
thanks for helping me choose
RWQ
the gpu on the a 10 is about 10% better than the a8 and
"s there going to be that big of a difference for the integrated vid card on the a10"
let me put it this way YES! ok with that said you need to understand that you should buy the asrock mb. whereas, the faster ram you can get with an apu the faster your video preformance. I.E. when you jump from 1600 ram to 1866 ram you see a 15-20% improvment in fps. so, in conclution buy the asrock board and get the fastest ram you can afford with the lowest timings.
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231638&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&AID=10446076&PID=3938566&SID=
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231621&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&AID=10446076&PID=3938566&SID=
thanks for your input i will take it into consideration
http://www.gamespot.com/forums/topic/29297334/a10-5800k-ram-preformance-results
