Which motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128546-$154
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157296-$110
I really don't see much of a difference between the two, but is one better for cpu overclocking and could one have a better sound card? I just want to know how much different these are and if it is worth the $45 to get the Gigabyte one.
Thanks for reading
We apologize for the inconvenience, but the item you are looking for has been deactivated. Here are some similar products that you may wish to consider:
ummm... they don't even list them any more
wait, you just had bad links. go with the z77 extreme4 by asrock
Oh... well here are the names of the motherboards
Gigabyte GA-Z77X-D3H LGA 1155
ASRock Z77 Pro4 LGA 1155
Sorry about that... first time that has happened to me.
Ok thanks man now I can get Medal of Honor Warfighter because it's in my budget :D
