Hi,
I currently have the following:
1 Desktop PC with 2 DP & 2 HDMI ports on GPU
1 Macbook Pro 2018 with 2 Thunderbolt/USBc ports
2 monitors with 1 DP & 1 HDMI port
I’m currently using my desktop with 2 DP cables to my monitors…
I just purchased the “Combo USB-C Power Delivery & DisplayPort 1.4 KVM - Dual Monitor” but after another review of instructions, I’m not sure I got the right model for my setup.
From what I understand, I would need to:
- Buy the USB-C Combiner. Use this to convert one of my desktop PC’s DP outputs into USB-C in order to connect it to the KVM.
- Buy a Moshi DP-to-USBC cable. Use this to connect my Macbook to the KVM.
Is this the most efficient/effective way to get me setup with 2 same monitors for this?
Generally, don’t really need to optimize for other peripherals as I use a logitech mx keys and mx master mouse that can easily switch between my devices with no KVM required.
Any advice would be appreciated - thanks!
