Between HDR and Anti-Aliasing, which one is best to use?
:D:D
:D:D
well AA is true smoothing of edges, but HDR makes stuff blury enough it proboly produces same effect lol, whatever you like I guess
so basically anti-aliasing is better? lol
i think i will just stock with AA
[img]http://www.tweakguides.com/images/Oblivion_19a.jpg[/img]
[img]http://www.tweakguides.com/images/Oblivion_19c.jpg[/img]
i say HDR ... AA just gets rid of jagged edges (use both if possible)
yeah i was just wondering but it said that when HDR is activated AA must be turned off and vice versa
This is oblivion probably, so use HDR. Bloom lighting sucks now.
Or you could use HDR and force AA in Nvida Control Panel or CCC.
In oblivion go for HDR, it's good.
I would think that HDR is better for performance than AA, or am I wrong?
I usually only use AA in older games to save fps, but I would prefer HDR over AA anyday.
HRD generally gives you better graphics and lighting effects.... you still might want to use aa to smooth it out the jaggies.
Remember not to bump the AA up to high, because then your FPS drops dramatically (Depending on the computer of course), but HDR does make things look prettier, give's it a more realistic look, and feel.
idk what the hell you're thinking
but you can use them both at the same time
il have to say anti-aliasing cus i can live without smooth textures and graphics and sames as HDR i live with out the HDR in gaming with combination of both you get excellent graphics and qulality in gaming so il av to say 50 to 50....
I use neither, my computer doesn't handle it so I just stick to max FPS =D
Anti-Aliasing!
