Which is better?
I remember seeing a youtube video about the 8350 and the I5 3570k. I was thinking about the 6300 vs the Phenom II x6 1045t OC to the same clock speed.
 If you take a look at the single and mutithreading benchmarks the 1100t is higher then the 6300.
http://www.anandtech.com/bench/Product/699?vs=203
Would you think the 1045t pull ahead since it has true cores?
Here is my benchmark from a different site, please excuse my sillyness from the image:
http://i.imgur.com/L4W7x9e.jpg
Different users:
http://gyazo.com/16f535243f063b65c4ea415b2a00313f
http://img.hwbot.org/u44545/image_id_906904.jpeg
you'll be lucky to get the X6 past 4Ghz
5Ghz is reasonable for the 6300
TR:DR get the 6300
yeah the FX-6300 is better and Logan did say that the Phenom || x6 (i think it was 1150t) was slower than the Phenom || x4 965 in most things!
I have an fx 6300, and I can feel this speed compared to other PC's. I think this benchmarks show it properly. Probably the best mid-range choice you can make:
http://www.cpubenchmark.net/high_end_cpus.html
I don't understand how the 1100t does better in gaming, and my benchmarks show that the 1045t at a lower clock beats the 6300 at a higher clock. (Both overclocked)
because the fx 6300 is just an update, not a "revolution". You can see in your benches, that the fx 6300 is good in other things. Things that need more cores. Or it's equal, the fx 6300 is just a solid update.
So upgrade when they come out with a new series for the AM3+ socket?
i'd keep the chip you have and upgrade to the new steamroller AM3+ chips at the end of the year.
Your not realy going to see much of a performance increase jumping from the 1045t  overclocked to a FX6300 to justify it ...not when the new chips are comeing soon
