I would recommend you not to buy a bundle because some part are good and some are not so good. 4770 k and a MSI or an Asus motherboard are ok, then the parts don't get so good: like the cooler and the RAM I would recommend you to buy a Noctua CPU cooler because they are the best CPU aircoolers on the market in heat dissipation and low noise. Which Noctua Cooler you choose is up to you but read the RAM compatibility list on the noctua page first because of the height issue for bigger cpu coolers. For the RAM You should buy quality RAM like a DDR3 1600 Kingston HyperX Beast or normal HyperX, go with the normal HyperX if you choose to go with a Noctua NH D14 (don't get the NH D14 2011 because only the mounting kit for socket 2011 is included). These mentioned parts are normally reliable but you will have to spend some more money. If you intend to overclock your Cpu, as far as I know are the Asus Motherboards a good choice, although I am a Gigabyte fanboy, I have to admit it.
If you are looking for places to buy near you a guy with the username Proximon on Tom's Hardware made a list of stores you can buy from all over the world.
Usually though, I think Overclock.co.uk, Aria.co.uk and Pixmania.co.uk(which i have used the french version of and is great.) Also Amazon and Ebay are good for buying parts.
If you tell us your budget and what you will be using it for, we can help you make a rig that fits you perfectly.
I don't even know if the Titan will be compatible with the new direct access system from RedHat for nVidia cards, but if there is one existing nVidia card that might work with it, it's the Titan, because of the large and fast memory.
So you'll want IOMMU on your system. Not only for that, but also because hardware virtualization is the single most important feature that any new system needs, it's the starting point of almost every performance and safety technology that comes out.
So use a "non-k" Intel CPU and a IOMMU (VT-d) compatible motherboard (AsRock, Gigabyte, MSI all carry IOMMU compatible mobos, check the motherboard on the kvm-compatible list on the internet). Asus uses a PCIe controller for it's Z-chipset boards that can't handle address translations, and therefore blocks IOMMU, and that's not the only problem, the PCIe controller Asus uses on those boards also causes a 10-30% drop in framerate because it bottlenecks, and that's without virtualization or low level access functions, just in current games. An Asus B75 chipset board for instance will perform up to 30% better in game framerate than an Asus Z77/Z87 board.
If you want ultimate performance, go for a socket 2011 system. If you want budget performance, go with an AMD FX6350 or FX8350 system, or a Haswell on a B/H-chipset board that supports IOMMU. There is no data yet on whether AMD Mantle will work on non-IOMMU Intel systems, but it makes sense to expect low level routines on the GPU to have to access the system memory directly, and for that you need IOMMU, because a routine running on the GPU will address its data one way, and the system CPU will address it another way, and there needs to be a translation in order to avoid confusion, and that's what IOMMU mainly does.
ok mate cheers will appreciate that because I don't want to do that again which I did before a few months back (buy an old xeon workstation again for gaming and spend loads of money on it now I cant sell it inc buying a gtx titan :((((( )
so....my max budget is 600 pounds! I know its not much but I can upgrade later on buy buying additional stuff for it when I get the funds.
well the ram is ok but the problem with that ram in particular is that its high profile. that means there is a large heat spreader on the ram it self, you will run into issues wenn you wanne install large cpu coolers, because they will cover the ram slots. especialy big coolers like the Phanteks PH-TC14PE or the Noctua N14D. so i would not recommend to buy that ram. also allways buy 2 sticks of ram, if you prfer 16 gb of ram no problem you can buy 2x8 G-skill snipers 1866mhz that fits the budget.
the Phanteks PH-TC14PE is one of the best air coolers to get.
That cpu cooler you posted i dont know it, but it looks very cool in my opinnion ☺120 mm fans will give you more space for rams offcourse. but the cool performance will be less then on the 2x 140 mm fans. on the phanteks. also a good choice for an aircooler will be the Xigmatek Darknight Hawk II. but for extreme overclockings i would recommend something like the phanteks. but its realy huge
Those G-skill snipers or G-skill ares ram´s, are totaly fine.
