Hi guys
I want to get a new gaming headset. I live in the Netherlands so prices a bit different out here then in the usa. I have to choose from the: HyperX Cloud(usb), Steelseries Siberia V2 (no usb) or the Plantronics GameCom 788 7.1 (usb).
This would be a easy choice to get the HyperX Cloud. But here is the problem. I have on-board audio, the Realtek ALC662 to be precise. Logan said that in his review it needs 60 Ohms and that it sounds muddy with on-board audio. So should I get the Siber V2 because it doesn't have such high Ohms requirements or the GameCom 788 because it has a usb connector (or would that also be restricted by the on-board?).
I am a total audio noob. I do not even know what Ohms are (derp).
Here are my full pc specs if needed:
- Intel Pentium G3258 (overclocked to 4.0 ghz)
- Asrock H81M-HDS
- 4gb 1333 mhz of HyperX fury ram
- Sapphire HD 7950 Boost OC edition
- Cooler Master G550M
- Seagate Berracuda HDD
- Corsair Spec-01 case
Hope you guys can help me out.
