Arctic LF II has fan cables routed through the AIO tube braiding and so as a result its just 1 header for all PWM fans and the pump.
The fans included are PWM p12s.
So should I connect to CPU_FAN header and control fan speed with PWM and will doing that affect Pump speed? Will that affect Pump lifespan?
Or
Should I connect to CPU_PUMP header and use it at 100% all time ? Since fan noise is a non issue personally.
