Hey Guys,
I have decided on the AMD Radeon R9 290, 290x series but I haven't decided between these two.
The Shapphire is a 290 with Vapor-X clocked at 1030Mhz Core clock and up to 1050Mhz in OC mode and effective frequency of 5.6 GHz. It has 2560 Shader Cores and 40 Compute units.
The Price is: £367.46
Here is a Link: http://www.dabs.com/products/msi-amd-radeon-r9-290x-4gb-pci-e-3-0-hdmi-gaming-962X.html?src=7
And the MSI is 290x where things get a little interesting. Its core clock is 1000Mhz up to 1040Mhz and effective frequency of 5 GHz. But it has 4 more compute uints and 2816 Shader Cores.
The Price is: £399.00
Here is a Link http://www.dabs.com/products/sapphire-technology-amd-radeon-r9-290-1050mhz-4gb-pci-e-3-0-hdmi-vapor-x-9CL5.html?src=7
So which one should I choose and what will the benefits be of one over the other. I'm looking for the slowest FPS degradation in the long run. And does the increase in Shader Cores and Compute units relay bring to the table.
Also here are the two builds I'm thinking of running one of them on.
Build 1: http://uk.pcpartpicker.com/p/3AW7W
Build 2: http://uk.pcpartpicker.com/p/3Cter
I'm leaning more towards the AMD but I can consider the Intel if can convince me.
