Which Fan is better for a airflow and a possible radiator
http://www.newegg.com/Product/Product.aspx?Item=N82E16835181054
OR
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103190
OR
For a radiator, screw both fans and get some GT15s before they're sold out (forever). For airflow, screw both fans and get some Cougars Vortexes or Noctuas.
Both fans you chose are pretty sucky.
I second the Noctuas, those things are absolutely amazing.
The Noctuas' are ugly as shit, maybe if they add some neutral case colors to them like black, I will consider it but until then for the millionth time no. And I am asking for which one of the 2 fans I asked from was better, nothing else.
