Hey everyone, first post here.
I'm about halfway into an X99 build for my girlfriend, black and white themed.
She wanted to go with a NZXT Source Elite 220 for something with a window and vents, that still looked low-key.
So far it has: Asus X99-Pro, Corsair AX760, i7-5820K, 16GB Corsair Ballistix Sport DDR4-2400 (4 x 4gb)
The issue I've ran into is I'm not sure what cooler to put in it.
The Elite 220 supports dual 140mm fans in the top, but the Asus X99-Pro has an 8 pin right at the top center, which has limited my space quite a bit. Between the 8 pin connector and the top of the case, I have around 25mm of wiggle room. I was going to originally go with a dual 140mm AIO water cooler, but most of those are coming in at over 25mm just in rad width.
I could go with a single 120mm cooler in the rear, but I would much rather have a dual in the top.
So the question is, are there any super slim AIO loops out there that would fit under 25mm?
Thanks for any help.
