if price isn't a problem look into the air540 from corsair it looks amazing with some led strips in it and you dont see any cables except the ones plugged in
Better front intake, optional bottom mounted intake fan with dust filter, offset mounts for 240mm top mounted radiator, fan controller for 3 fans, plus it has a window to show off all your sexy components.
Only on the windowed model, which you neglected to specify. The Fractal case, on the other hand, only comes with a windowed side panel. Personally, I much prefer the aesthetics of the Corsair case, and if you aren't planning on liquid cooling it, then that case would work swimmingly. If you want a dual 120mm rad in the top, then the Fractal case has better accommodations for a push/pull configuration.
Indeed. It's all preference, really. The fractal case can fit thicker radiators and/or more fans if you plan on going with a 240mm radiator (or dual 120... depends on how your brain works). THe fractal also has a foam layer in the top grill giving it a touch of sound dampening. The windowed corsair does have a larger window, if you want to see your hard drives and your psu. Just note that if you plan on using a CD drive, it will disrupt the look of the front of the case
