So im building a new gaming rig and need to pick a case I've narrowed it down to these five which one should i get/is the best i know three of the cases are mid towers being compared to two full towers. But putting that aside which case should i get?
Just on pure looks, the regular Rosewill blackhawk, and forgive me for this, though might I suggest the Corsair 600T? I have that and it looks beautiful, I myself am a large fan of the 'clean' look, meaning smooth curves and clean lines, not like any of the cases you pointed out just here other than the blackhawk.
But Might I suggest, more importantly, decide on your budget for a case, find the cases that match that budget the closest, look at what they have to offer in terms of design features, such as space for radiators, tool-less HDD cages, cable managment options, then use the features of the case to narrow down your selection to make your choice easier.
I decided on this 500r. http://www.newegg.ca/Product/Product.aspx?Item=N82E16811139010 Did i make a good choice? It was on sale for 110$, free shipping and 30$ mail in rebate.
Just did a build for a client not even 2 months ago. One of the nicest cheaper cases I've ever used. For just above $100 dollars it has features that 300 dollar cases dont have.
