Which Case Is Better?
  • Gigabyte GZ-PD Plus ATX Mid Tower Case
  • NZXT Source 210 Elite
Which case do you guys think is better? I'm thinking about just getting the Gigabyte case due to price. What do you guys think?
The NZXT by far. The tooless design is alot nicer than the 1990s internal styling of the gigabyte case aswell as the build quality looks ALOT better. also looks like there is room behind where the mobo mounts for cable management. Ignore the gigabyte case and just order that NZXT lol.
The build quality of the gigabyte case looks very poor, I wouldn't be surprised if the metal was really flimsy.
Thanks a lot! Will be going with the NZXT case for sure now lol. Do you know any place that might have a Black Friday deal for this case?
Cheapest I see it around is on Amazon for 42.98
http://www.amazon.com/NZXT-Source-210-ELITE-Midtower/dp/B005869IUY
make sure you choose the Black one under color options. (assuming you wanted black)
NZXT, better cable managment.
NZXT. So I think you got your answer
