Which cards use less pcie bandwidth?
so my question is which team, nvdia or amd, perform better with less pcie bandwidth. like which teams current cards will perform best using a pcie gen 1 1x connection.
750ti or 270
 depends which game imo
I don't know if it matters. At a certain point it bottlenecks regardless of which brand you buy.  Probably the 750ti or r265 would be best for pcie 1.1 if memory serves about 1.1.
the speed is 250mbps, i hear maxwell has better use of bandwidth with its color compression algorithms, but past benchmarks from 2007 show amd doing really well with low pcie bandwidth. im doing an egpu through mini pcie btw.
It probably doesn't matter then, just get whatever card works best for your budget.
why doesnt it matter? wouldnt the card that best utilizes its available bandwidth perform better for me? im just unsure which team will do that, nvidia or amd, seems like nvidia currently but im not sure.
Cause they do it about the same. The issue is more of a card by card than a than a vendor.
