Which Card should I get? PLZ Help!
Before everyone starts hating and saying it doesn't matter which brand I just want to know if I should get a <http://www.newegg.com/Product/Product.aspx?Item=14-202-006&SortField=0&SummaryType=0&Pagesize=10&PurchaseMark=&SelectedRating=5&VideoOnlyMark=False&VendorMark=&IsFeedbackTab=true&Keywords=%28keywords%29&Page=1#scrollFullInfo>
or a
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150588
The Sapphire will be just as good, if not better than the XFX and is also cheaper, so it would be an obvious choice if it were me.
OK thats what I was leaning towards plus it's cheaper so I will be a happy camper.
I had some bad experiences with XFX in the past... The saphire cards work awesome, I never had problems with them!
If you can deal with the color of the PCB, or it goes with your build, then it is an excellent choice.
