Hi all
Im in the process of putting together a new workstation on the x99 platform and am thinking about which gpu to get. I will be playing the occasional game on the machine, but it will mostly be used for 3D work and compositing. These are the applications I typically use:
- Zbrush: 3D sculpting (entirely software rendered so gpu wont make a difference here)
- Mari: texturing (capable of handling multiple 32k textures, but I usually work at 8k)
- Maya: animation and simulations
- Nuke: compositing (like a node based after effects with a little bit of cuda acceleration here and there but nothing major)
The first 2 (zbrush and mari) are sometimes replaced by Mudbox depending on the situation
If I had to list, in order, how much I use each program it would probably look something like: Nuke > Zbrush > Mari > Maya
OK so onto the GPUs. I won't be getting a workstation card as they are too expensive for what they do. I'm considering the following:
1. GTX 770 (Gigabyte, 4gb, 1.14ghz) - $460
2. R9 280x (MSI, 6gb, 1ghz) - $475
3. R9 290 (Sapphire TriX, 4gb, 1ghz) - $475
4. GTX 760 (EVGA, 4gb, 1.08ghz) - $366
5. R9 280 (Gigabyte, 3gb, 950mhz) - $250
First of all, if money were no issue, which card (from the list) is going to be best for my work?
Next, when considering price/performance ratio, do one of the cheaper cards work out better?
Is there a preference for AMD (opencl) over Nvidia (CUDA) in the applications I use?
How much does vram matter for a workstation like this? Does clock speed matter? Do neither matter to the point where I can just get a cheap 760/r9 280?
thanks!
