Which card for 1080p gaming?
So I'm looking at some different gpus right now to put in my first system build. I'm stuck between the 270x, 760 and 770. I will be playing at 1080p like I said and definitely Battlefield and heavily modding Skyrim and Fallout's. I have $105 gift cards to best buy and they have some really awesome prices on the 770 but I don't know if its worth the extra $60 over the 760 OC. I can get a PNY 770 for $312 and 760 for $250 or cheaper, and 270x from a different site because I'll just use best buy for RAM and HDD. What should I buy?
Hmmm... if you can afford the 770, you might stretch to the 280x. The 280x will handle Skyrim mods much more capably because of the additional Vram and mods seem to love AMD drivers.
However, the 280x is a little over-priced right now. Previously, it was the cheaper option.
Anything from the 7770 upwards will allow you to play games at 1080p. Though, I would look to the higher-tier GPUs if you want to use a great number of mods.
Finally, the 270x (rebranded 7870) will play 9 out of 10 games on ultra settings without heavy use of mods.
I just looked at the 280x and its about $90 more than the 770 so thats out of my price range. I'm guessing the 760 could run modded games better than the 270x because it's a much more powerful card, but even if it doesn't, it still runs most games better.
Depends where you are purchasing from. I have seen 280x cards for $30-40 more than the 770. Perhaps I was looking at the most expensive 770 and the cheapest 280x.
The 760 is a really balanced card for 1080p. Will allow you to play almost all games on ultra at 1080p, with the exception of demanding games that punish any given hardware setup.
I would say that the 760 would edge out the 270x in modded Skyrim. Though, the 270x wouldn't bee too far behind.
The 770 is pretty good for modding, and it has quite a lot of juice to compensate for any loss in performance. I would probably choose the 770, if the price of the 280x is too high.
Could I expect the 280x price to go down due to the litecoin frenzy has died out? Or was that mainly for the 7950's? I'll keep my eyes open for the 280x.
All AMD cards have increased in price due to all kinds of crypto-currency (dogecoin, catcoin(?), litecoin, bitcoin). While the value of those currencies fell sharply, it does seem to be on the rise once again >.>
Depends when you decide to buy. The 280x is perfect for modded Skyrim. But right now the 770 seems like the better buy, and probably for the foreseeable future.
Ok, It sounds like I'm leaning towards the 770 due to the fact that its cheaper and It also a very well rounded card. I will be missing out on mantle when that comes into affect for BF4 which I'm sure will be very nice but the 770 can already run it fine at 1080p. The monitor is also running at 60hz but I'm sure you assumed that already anyways. I'm switching from console so anything is an upgrade at this point haha.
Mantle isn't exclusive to AMD. Competitors could utilise Mantle with a patch. Though, we don't know if they will do that.
The 770 is a kick ass card if you have been playing on console. I think you've chosen the right time to move away from that platform. No mods, and more expensive than the consoles are truly worth.
I guess I shouldn't say I'm switching, because I'm not completely giving up console, since my XBL just got renewed for a year, I'll probably run it out the rest of the year while having this PC and then may sell my xbox, which actually just came into my mind as I was writing this! But I have an OK laptop, it can handle some games modded, but only a little, and I'm not one for multiple playthroughs, just continuing so I don't want to start FO3 or NV and Skyrim and then start over on the new PC, unless I can transfer saves. But I'm really looking forward to switching. I got a bunch of gift cards for christmas so I actually can fit a 770 and monitor with all the other component's for under $650, so pretty kick ass.
http://pcpartpicker.com/p/2pQ8I
Thats what I have right picked out right now, I have the gift cards factored in.
It looks like you've done your homework! Don't think I am being too critical, but you might want to buy 2x 4GB sticks of RAM. That will enable you to use dual channel memory which is faster than single channel.
Alternately, you could just grab a single 4GB stick, enabling you to upgrade to 8GB later. You only need 4GB to run games. 8GB is the sweet spot, though. And the price of RAM is sky-rocketing, so it might be advisable to grab 8GB as soon as possible. But you should really look to grab two sticks, as I mentioned.
I keep changing the build so save penny's on the dollar but I just added the single channel today and cut the other 2 channel kit. But ya, I've been wanting to build a computer for a solid 1 1/2 years now and I'm finally getting to that point. So I have done PLENTY of homework haha. I know about a lot of this stuff now, components and different things I guess, the next step is just buying one now!
"Dual channel kit" is misleading. Any two sticks of RAM are "dual channel" :P
Dual channel has everything to do with the motherboard's access to memory, not the RAM itself. e.g some motherboards support quad channel memory, which just means it can access 4 sticks of RAM.
So yeah, grab the two sticks, it shouldn't cost you more than a few dollars in difference. And it is twice as fast as a single stick. You absolutely must have dual channel - wouldn't want people to think that you are a noob
Well you learn something every day! I didn't realize that because I swear I have read things in the past saying it doesn't matter but never really did any investigating for myself. It only costs $10 more, but geez, RAM prices have been going up. I would think they would be going down because were getting close to where DDR4 will be coming out. And if I'm correct, AMD chipset can't take use 2133 Mhz RAM, because theres some on sale right now on newegg for $60.
End of the line DDR3 will go up in price as it becomes scarce. It has been on the rise for a while, but prices shot up astronomically after one of three major factories that manufacture memory burnt down.
8GB will cover your gaming needs for the lifetime of your system. A good 5 years or more with a GPU refresh, or whenever you cease to be satisfied with it.
You only need 1333 or 1600 for gaming. Higher clocked RAM is increasingly unstable, and it doesn't give you a tangible boost in performance unless you are using an APU - you're not using an APU.
Ya I realize that it gave you a performance boost for an APU, which wouldn't be bad for my laptop. I just wasn't sure because it's on sale so I figured why not. I could just wait for a newegg daily deal thing, they always have an 8 gb kit on there pretty much once a week. It's funny listening to people that have computers and they have 8 gb+ of RAM and they complain that their computer is too slow so they need more. I know more is better but when all you do is surf the web and play games theres no need. He was like like ya, I have the internet open and I'll be playing skyrim, MOAR RAM!
If you have a gazillion internet tabs open, that can really tax your RAM. But yeah, it would have to be a stupid amount to utilise much more than 8GB.
I honestly think you're pretty damn close to - all prices and things considered - an ideal system. A really balanced/appropriate system, I should add.
If you had a couple of spare dollars I might recommend a couple of other bits. but there's nothing wrong with the build.
And if higher clocked RAM goes on sale, it isn't going to do much harm if you pick some up. Get whatever is cheapest. RAM is largely just RAM.
Ya I would add some things too but I'm trying to get the most performance for the cheapest price. My parents are really fickle with how I spend my money so I'm trying to keep the cost around $650 and not much more. I would like to get a better monitor but again the GPU is more important, and that and the cpu are all things that I could upgrade and wouldn't be as much of a problem as upgrading the GPU. I will definitely get a CPU cooler soon after as well, maybe I can see if my dad could buy it come time when were at micro center haha.
Sometimes it is worth spending the extra few dollars to get something that might be of higher quality, or has certain features.
I'm glad to see the G46 motherboard and not the G43. The G43 has a lack of heatsinks. That would be a prime example. There's always some "improvement" that can be made, but it is a question of how much that improvement costs versus whatever is gained. That can be largely subjective.
I mean, I did just buy a new power supply because my old one was the wrong colour. It was pissing me off for months!
Hahaha! Well I think Microcenter only carries the G46 so thats good. I have a store close to me and I can get that and the 6300 for $120, THATS A STEAL! But I would like to add some case fans, maybe an upgrade in the case. But I'm pretty satisfied that I can now fit the 770 into my budget, and the 760 under what I had originally. So I think I'm in a sweet spot right now. What would you suggest I could improve on the build without drastically changing the price?
