I have saved up £600 and have made two builds that i could make, what does everyone think about them and which one should I build?
http://uk.pcpartpicker.com/p/3mzHs
http://uk.pcpartpicker.com/p/2WQxj
I would really appreciate it if you could help me decide.
The Intel build, I would just recommend changing the PSU.
Here my revision of your intel build:
http://uk.pcpartpicker.com/p/3mDxx
Another alternative Intel build is this if you are willing to change the case and leave out the 1TB hard drive. However, you could get a 1TB HDD first then a SSD if you wanted:
http://uk.pcpartpicker.com/p/3mDCB
