Which Build is Better?
So which build is better. I have both an AMD and an Intel option. I just need your thoughts because Im kind of stumped. I heard that Socket 1155 is dead? Which that is making me lean more towards AMD. I dont know.
Intel: http://pcpartpicker.com/p/C8Ys
AMD: http://pcpartpicker.com/p/Cp4i
Please Leave Your Thoughts! I really need them.
AMD, easy. The 7950 throws down with the 670, so the AMD side has a potent CPU and better graphics. Yes, 1155 is a dead socket, meaning there will NOT be another processor available for that socket. No upgrades. And the AMD side, you will have the option to upgrade to Steamroller when it comes out.
And if the rumor is true about one of the next gen consoles using 8 cores, we may very well see games optimized for that in the future.
