Which build is best for $500
Hi guys.
My budget really keeps changing from ridiculous amounts. Last week my budget was $1,000, then $650, then $800, and now I'm at a definitive $500 budget. I did look at Logan's recent $550 build, and I did try to base some of the parts off that video.
I want to build a $500 gaming PC that will play any game out there at at least high details, at a good framerate (preferably 45-60) at 1920x1080. I've come up with two builds that are around this budget, and I want to know which one is better for gaming.
I will (eventually) be adding an SSD, and I will (eventually) be running the GPU's in 2-way Crossfire, and I want my CPU to have a small-none bottleneck, if possible.
http://pcpartpicker.com/p/qpxp (965 BE, 7870)
http://pcpartpicker.com/p/qpNn (i3-2100, 7850)
And yes, I'm going to be a complete 12 year old and pirate Win7 onto a USB drive and install it from there.
Or if you guys have any other completely different builds at this price point, leave them down below
Gracias.
and at that PP, get an A10
You don't think I should get a discrete GPU at a $500 PP?
