Which Build Do I choose?
Ok, so I'm building My first PC and I have put together 2 different PCs and i need to know which one is best for me. I will be using adobe Photoshop, premier pro, light room, after effects. I will also be playing mainly battlefield 4, Crysis 3, GTA 4, COD ghost, and minecraft.
First Build: http://pcpartpicker.com/p/1YYvr
Second Build: http://pcpartpicker.com/p/1YYNT
The main thing i want to know is if the first build is worth the extra 90$
The first one, because I prefer Intel.
the one that best express your unique personality.
For $90 you could up the gpu to something a lot better.
So build 2 + better gpu.
btw, i would advise you to swap out the psu to something better.
The i7 build would be my choice.
Suggestions:
PSU:  CoolMax's PSUs are generally pretty low quality.  Something like this would be better: http://pcpartpicker.com/part/fractal-design-power-supply-fdpsuin2b750w
