I know they are the same basically but idk if i want a better MOBO for overclocking
(i will be using the pc for 3monitor gaming thats y i went overkill on psu so i can get cross-fire l8er and streaming rendering and a bit of video editing with sony vegas)
(i also no that i dont have a cpu cooler but i will get one l8er on in the future)
My suggestion is the first one, but with the MSI 7970. I know it's a little over budget but you WILL thank me later. That machine will run great. Happy building!
Absolutely crazy build, but, what the hell. Anyway, much better MSI board, lots of unnecessarily fast RAM, a Radeon HD 7970, an SSD with a fair amount of space, and liquid cooling in a case that has a window and a fan control slider. I think this is one of the most efficient uses of money I could build while getting a halfway decent case with a window... Unfortunately, it does limit the placement of the cooler to the rear ventilation point, so you might want to hunt your own case if that is a problem for you.
Eh, if you have a modern enough board with fast enough RAM that happens to match, with a program that happens to be able to use that amount of RAM, then it is faster, sometimes significantly so. But it is relatively uncommon a use. So more or less, it is so that you can have more applications open without having to use a paging file on the HDD or SSD. RAM is still many figures faster even than an SSD. Not saying you are entirely wrong, but you also aren't correct either.
the i7 3770k is a Quadcore with HT can do 8 threads <-- not a real 8 core
the FX8350 is a real 8 core. can also do 8 threads
wenn games gonne be optimized for 6 cores in the futere, then the i7 is dead, the amd would still do a good job theoraticley, so lets about 3 years games will probabley optimized for 6 cores, then you need to upgrade youre whole intel system.
on the amd cpu you can still play those games, thats why the amd is more future proof. you maybe only need to upgrade a gpu till that time..
but this is only the way im thinking of it, based on nothing!
